2.6.5 has been tested internally to work with arcpy?
Is there any hit on performance with this scenario?
ArcGIS 10 final will ship with one and only one version of python. At Pre-release we have 2.6.2. Most probably for 10 final we will have 2.6.5. Having said that, ArcGIS 10 will work with any 2.6 version of python. So say 6 months from now, we have Python 2.6.6 released but ArcGIS is using only 2.6.5, you can safely install Python 2.6.6 and ArcGIS will work ok. Note that this compatibility works only with a major release of Python. In other words ArcGIS 10 will never work with Python 2.7 or Python 3.1 or any other major release of python. Only Python 2.6 is supported.
Also note that you should also install numpy 1.3.0 BEFORE installing ArcGIS 10. Only installing Python 2.6.5 and not installing numpy 1.3.0 WILL confuse the ArcGIS 10 installer (at pre-release) and you will get unwanted results. So always keep Python 2.6.x and Numpy 1.3.0 together and things will work well.
Deelesh
I am using a student license of ArcMap 10 (build 2414) and I would like to get Arcpy working. I did not install Python or Numpy before installing Arc.
Is the only solution for me to completely uninstall Arc, install Python 2.6 & Numpy 1.3 and reinstall Arc?
Thanks!
Should be able to just install python and numpy, and then change the .pth file, rather than re installing ArcGIS.
