flederfauz
UpdateLayer Problems with Layers that use Representations and Annotations
Discussion created by flederfauz on Sep 26, 2011
Hi!
I wrote some code that updates Layer properties in a map with source Layers in a folder.  The first thing I discovered that arcpy.mapping.UpdateLayer can not process input from Layers whose path includes a Folder with numbers only (in my case *\2011\*). When I finally discovered I changed the name and it was ok.
But; when the Script runs over a Layer using Representations or an Annotation I get the following message: LayerObject: Get attribute renderer does not exist.
Am I right assuming that I can not access those objects? If so how can I sort them out? And how can I update them with antother method?
Thanks a lot
Chris
here my code
import arcpy
from arcpy import env
import os
#Set the mxd to the currently opened map
mxd = arcpy.mapping.MapDocument("CURRENT")
#Get workspace where the master Layers which layout and properties you want to
#copy are stored e.g. C:/SourceLayers "P:/RAME/GIS/Layers"
env.workspace="P:/RAME/GIS/Layers" #arcpy.GetParameterAsText(0)
#Decide if All Properties or only Symbology is updated. Default is FALSE
SymbologyOnly="True"#arcpy.GetParameterAsText(1)
#Create a List for each layer in your Source Folder containing Name and Path
fcList=[]
mxdlyr=[]
for file in arcpy.ListFiles("*.lyr"):
   name = os.path.splitext(file)[0] + ".lyr"
   head, sep, tail = name.partition('.lyr')
   name=str(head)
   path=str(env.workspace+"\\"+file)
   tempList=[[name, path]]
   fcList.extend(tempList)
# loop through layers to get layer names and replace layer file
dfs = arcpy.mapping.ListDataFrames(mxd,"*")
for mxdLayer in arcpy.mapping.ListLayers(mxd,"",""):
   temp2= str(mxdLayer.name)
   mxdlyr.extend([temp2])
x = mxdlyr
y = fcList
#find the source layers that exist in the mxd
def find_match(x, y):
   match = []
   for i in x:
      for j in y:
         if i == j[0]:
            match.append(j)
   return match
match = find_match(x, y) # create a generator
#Loop through all Dataframes
for df in dfs:
   dfName=df.name
   #Loop through all Layers of the match list(source layers that exist in the mxd)
   for fc in match:
      #get the name of the layer out of the list
      tempname=fc[0]
      print tempname
      #get thesource path of the layer out of the list
      tempname2=fc[1]
      print tempname2
      #Prepare the variables used in the UpdateLayer Command
      df = arcpy.mapping.ListDataFrames(mxd, dfName)[0]
      updateLayer = arcpy.mapping.ListLayers(mxd, tempname, df)
      print updateLayer
      sourceLayer = arcpy.mapping.Layer(tempname2)
      print sourceLayer
      #Steps through all Layers in the mxd with the same Name and updates them
      x=0
      for lyrs in updateLayer:
         updateLayer = arcpy.mapping.ListLayers(mxd, tempname, df) [x]
         x =x+1
         arcpy.mapping.UpdateLayer(df, updateLayer, sourceLayer, SymbologyOnly)
# refresh view and table of contents, save changes to mxd
      arcpy.RefreshActiveView()
      arcpy.RefreshTOC()
      mxd.save()
#Tidy up
del sourceLayer, mxd
Outcomes
