Hi guys,
Some feedback...
- arcpy.featureClassToShapefile_conversion("Sample_Routing\Routes", "E:\\")
This appears to work, but then says it had a problem naming the output. Which is odd, as this isn't even a parameter in the code.
- arcpy.CopyFeatures_management("Sample_Routing\Routes", "test")
I didn't think that this would work, but it does. It makes a shapefile of the Routes and saves them to the default location. Note, there's no need for .shp in the code.
-arcpy.FeatureClassToFeatureClass_conversion(in_features, out_path, out_name)
- Although rather strangely named (how is feature to feature a conversion?), this also makes a shapefile as its output.
So in summary, thanks!
James
