Popup Click Tolerance
3342
09-28-2011 12:23 PM
BrianMorgan
I am using the ArcGIS Viewer for Flex 2.4 for an application that requires the addition of zoom scales down to 1:282.  While popups work fine at small scales, as you zoom in further it becomes difficult to trigger the popup, and the actual point that you need to click moves several pixels to the south.
Is there a way to adjust the click point or increase the tolerance, and if so, where would I make this change?
Thanks in advance for any help that you can provide!
BrianMorgan
Crickets...
MGSethe
Crickets...
Oops , i have the same problem  here , did you get this solved ? Please help
BrianMorgan
After a few technical support sessions, no real solution was determined, but a work-around approach is to adjust the X and/or Y offset in ArcMap to compensate.  It kind of works.
RichardTruong
New Contributor III
Hi Brian,
You'd mentioned a work-around from ArcMap in term of X/Y offset.   Would you be kindly to elaborate this a bit more, because I do have the same issue as you do.   Thank you,
