try: import arcpy.mapping, os, sys, string, traceback mxd = arcpy.mapping.MapDocument("CURRENT") for dataframe in arcpy.mapping.ListDataFrames(mxd): BrokenLinkList = arcpy.mapping.ListBrokenDataSources(dataframe) for item in BrokenLinkList: print item.datasetName if item.datasetName == r"LummiReservationFullBoundary": print "droppin' in" #The path to the new directory... newWorkspace = r"Z:\Data\Boundaries\Administrative\Lummi.gdb\TribalBoundaries" #The new dataset name... datasetName = r"LummiReservation" #This should have a "FEATUREDATASET" options to replace FILEGDB_WORKSPACE. item.replaceDataSource (newWorkspace, "FILEGDB_WORKSPACE", datasetName, False) arcpy.RefreshTOC() #mxd.save() del mxd print "Done" except arcpy.ExecuteError: msgs = arcpy.GetMessages(2) arcpy.AddError(msgs) print msgs except: tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1]) msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n" arcpy.AddError(pymsg) arcpy.AddError(msgs) print pymsg + "\n" print msgs
Solved! Go to Solution.
