How to increase symbol sizes in legend
5734
7
11-22-2011 03:06 AM
GeorgeShi
Hi all,
I would like to increase symbol sizes of layers in the map legend control a bit. Any advises?
Thanks in advance!
George
DominiqueBroux
Esri Frequent Contributor
You have to change the LegendItemTemplate in order to change the way the symbols are displayed the legend.
A first naive version, setting a fixed size for the symbol, would be :
<esri:Legend.LegendItemTemplate>
  <DataTemplate>
    <StackPanel Orientation="Horizontal">
      <Image Source="{Binding ImageSource}" HorizontalAlignment="Center" VerticalAlignment="Center" Height="30" Width="50" />
      <TextBlock Text="{Binding Label}" Margin="5,0,0,0" VerticalAlignment="Center" />
    </StackPanel>
  </DataTemplate>
</esri:Legend.LegendItemTemplate>
The issue with this version is that the symbol size in the legend is no more related to the symbol size in the map (always 30*50).
If you want to keep a relative size, you can use a multiplication converter to increase or decrease the symbol size with a fixed ratio:
  <DataTemplate>
      <StackPanel.Resources>
        <esri:MultiplicationConverter x:Key="multiplicationConverter" />
      </StackPanel.Resources>
      <Image x:Name="img" Source="{Binding ImageSource}" Stretch="Uniform" MinWidth="25"
            Height="{Binding Source.PixelHeight, ElementName=img, FallbackValue=25, Converter={StaticResource multiplicationConverter}, ConverterParameter=1.4}"
            Width="{Binding Source.PixelWidth, ElementName=img, FallbackValue=25, Converter={StaticResource multiplicationConverter}, ConverterParameter=1.4}"
            Margin="0,0,5,0">
      </Image>
    </StackPanel>
  </DataTemplate>
Note : adapt the ConverterParameter value to your need.
GeorgeShi
Hi Dominique,
Thank you very much for the advice.
Could you give me some advices on how to increase sizes for specific layers programmatically?
When I have the "LegendItemViewMode" reference and the reference to its �??ImageSource�?� for a specific layer, can I increase image size through these references?
Your suggestions are very much appreciated.
Regards,
George Shi
DominiqueBroux
Hi George,
I am curious but why do you want to increase the symbol sizes in the legend control for some layers only?
In fact, I am just wondering whether I understood well your need.
I understood that you need to change the symbol sizes in the legend without changing anything in the map (i.e just a way to get a smaller or larger legend control without changing the map rendering)
If you need to change the symbol sizes in the map, my answer is not adapted at all. In this case you have to change the renderers and the legend will change automatically.
GeorgeShi
Hi Dominique,
For some layers (e.g. point layers with marker symbols), users want us to make the icons a little bit larger in the legend, for example the icon for �??Documents�?� sub-layer in the attached screen shot, without changing symbols showing on the map.  Icons for other layers (e.g. a square for �??GeoFrame Seismic�?� in the attachment) in the legend are ok. Therefore, users want to keep them as they are.
Any advices?
Thank you again for your help.
Regards,
George
DominiqueBroux
OK. I got your use case.
One option is to use the LegendItemViewModel Tag property to store the expected image size and to initialize this expected image size by code.
For example, we can store the image size as a Tuple { Height, Width}.
So your LegendItemTemplate becomes:
  <DataTemplate>
      <Image Source="{Binding ImageSource}" Stretch="Uniform" MinWidth="20"
                  Height="{Binding Tag.Item1}"
                  Width="{Binding Tag.Item2}"/>
    </StackPanel>
  </DataTemplate>
And you have to initialize the tag by code in the Legend.Refreshed event handler:
private void Legend_Refreshed(object sender, Legend.RefreshedEventArgs e)
  if (e.LayerItem.LegendItems != null)
    foreach (var item in e.LayerItem.LegendItems) // loop on legendItems at the layer level
      SetTag(item, e.LayerItem.Layer);
  if (e.LayerItem.LayerItems != null)
    foreach (var subitem in e.LayerItem.LayerItems.Where(layerItem => layerItem.LegendItems != null).SelectMany(item => item.LegendItems)) // loop on legendItems at the sublayer level
      SetTag(subitem, e.LayerItem.Layer);
// Set the Tag with the expected size of the legend swatch
private static void SetTag(LegendItemViewModel item, Layer layer)
  double ratio = layer is FeatureLayer ? 1 : 1.5; // size based on the layer type (for the sample sake)
  var source = item.ImageSource as BitmapSource;
  if (source != null)
    item.Tag = new Tuple<double, double>(source.PixelHeight*ratio, source.PixelWidth*ratio);
Hope this helps.
GeorgeShi
It works!
Big appreciation to Dominique! Thanks a lot!!
Regards,
George Shi
DominiqueBroux
Glad that works for you.
Thansk for your appreciation.
