Change Mouse Cursor when hovering a feature
4298
5
11-23-2011 04:23 AM
oo
Is there a simple way to change the mouse cursor when I roll over an object (e.g. a street) on a feature layer? How?
Is the same possible for a DynamicMapServiceLayer e.g. via it's GraphicsLayer?
JenniferNery
These threads seem related:
http://forums.arcgis.com/threads/21708-Does-arcgis-provide-a-Pan-cursor.
http://forums.arcgis.com/threads/8182-Map-Cursors
Features in ArcGISDynamicMapServiceLayer do not receive mouse events. You would have to use FeatureLayer to enable this.
OrenGal
New Contributor III
Maybe you find this post helpful. Change the cursor after querying the server.
http://www.gal-systems.com/2011/09/showing-arcgis-dynamic-layer-maptips.html
Oren.
oo
Thanks for the links.
I do not need a custom cursor. My plan was to listen to the feature layer's MouseEnter/Leave events and then trigger a cursor change (to another default cursor) like "Map.setMapCursor("pointer")" in the JavaScript API. But I can't find an equivalent method in the SiverLight API. What can I do?
DominiqueBroux
Esri Frequent Contributor
There is a Cursor property on the Map.
By wiring up the MouseEnter and MouseLeave FeatureLayer events, you can change the cursor with code like:
private void FeatureLayer_MouseEnter(object sender, GraphicMouseEventArgs e)
  MyMap.Cursor = Cursors.Hand;
private void FeatureLayer_MouseLeave(object sender, GraphicMouseEventArgs e)
  MyMap.Cursor = Cursors.Arrow;
oo
Thank you! That's what I was looking for.
