Natural Breaks Analysis Within Python
4786
11-28-2011 05:07 AM
JeremyTibbetts1
Hello all,
I have a field within a features class that needs to be classified base on natural breaks. I was wondering if there is way in python scripting to find the field within the FC and then determine the natural breaks within the data set? The number of categories I am going for is 5.
My skills in python are somewhat limited, i'm slowly learning as I go, but any help would be appreciated.
Jeremy
JeffBarrette
In 10.0, the only way is to pre-author a layer file with all the appropriate information and then use arcpy.mapping.UpdateLayer.
At 10.1, we have introduced some symbology properties for some of the renderers that will allow you to change fields, number of classes, class breaks, etc.
Jeff
KailaiZhang
You might want to take a look at the Apply Symbology From Layer tool in 10:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000006n000000
For 10.1, you can use the new RasterClassifiedSymbology class in the ArcPy Mapping module:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s30000005p000000
Kailai
GalAvraham
Jeremy
Take a look at this link - it includes an implementation of Jenks�?? Natural Breaks Algorithm, in Python.
http://danieljlewis.org/2010/06/07/jenks-natural-breaks-algorithm-in-python/
Keep in mind that the number of classes is yet to be determined by the user. Here's a direct the link to the algorithm:
http://danieljlewis.org/files/2010/06/Jenks.pdf
Cheers,
Gal
