Trouble Deleting Domains
4545
19
12-02-2011 09:03 AM
TomKoritansky
Hello everyone,
I'm having trouble deleting a domain list from my file geodatabase.  When I try to delete to domain I get an error that says:
"Failed to a delete domain from the database.
The domain was not found.
The domain was not found. [name of domain]"
I also cannot add any new entries to the domain or change the domain name and description; I get a similar error that says:
"Failed to update a domain.
The domain was not found."
The domain is not attached to any attribute fields.
One thing I noticed was that if I try to edit the domain name a box symbol appears at the end of the domain name when cursor is in the window to type more text.
Any suggestions?
EstherFernández_García
Hi tkoritan,
Did you ever find the solution to this problem. I'm having the same issue...
Thanks and best regards
Esther
JackZHANG
Occasional Contributor II
Same problem here.
TomKoritansky
No, I never found a solution to the problem.
SrijanaTuladhar
New Contributor III
Hi, I am having a same problem. Any one figured out this solution? Thanks.
GeorgiyYaroslavtsev
So... after 6 years... Maybe ESRI answer us what to do with this problem?
shan_sarkar
Occasional Contributor III
Tom,
  1. Are you trying to delete the domain from ArcGIS Pro or ArcGIS Desktop? What is the version of ArcGIS Pro or ArcGIS Desktop?
  2. Is it a coded value or range domain?
  3. Have you assigned the domains in any feature class or standalone database table?
  4. Does it give the same error if you try using Delete Domain—Help | ArcGIS Desktop ?
~Shan
~Shan
GeorgiyYaroslavtsev
Can I answer, if you don't mind?
1. I use ArcGIS Desktop v.10.5
2. It's range domain of small integer type
3. No, domain not assined to any feature class
4. Yes, it does
shan_sarkar
What kind of a database is being used here?
~Shan
GeorgiyYaroslavtsev
It's file geodatabase
