C# FGDB API crashing on some systems running ArcGIS 9.3.1
2529
01-04-2012 12:48 PM
ArtUllman
I am having a problem deploying the C# FGDB API to 'some' systems.  I have copied ESRI.FileGDBAIP.dll, FILEGDBAPI.dll and FileGDBAPID.dll to the same directory as the executable.  All systems are running the same version of the .Net Framework - v4.0.30319.  I put a try/catch around the geodatabase open, but it still crashes immediately on execution.  This is a 20 line program that tries to read a table from an FGDB.  I am seeing the error on systems running older versions of ArcGIS - specifically 9.3.1.  I am not seeing the error on systems running ArcGIS 10.  My understanding is that the API should be independant of any ArcGIS install.  Is this correct or is there a dependancy on ArcGIS Desktop libraries?  Are there any additional installs besides dropping the DLLs into the directory with the executable?  It is a simple WPF app.
Here is the event:
Application: TestFGDB.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
Stack:
   at TestFGDB.MainWindow.click_button(System.Object, System.Windows.RoutedEventArgs)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean)
   at System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject, System.Windows.RoutedEventArgs)
   at System.Windows.UIElement.RaiseEvent(System.Windows.RoutedEventArgs)
   at System.Windows.Controls.Primitives.ButtonBase.OnClick()
   at System.Windows.Controls.Button.OnClick()
   at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(System.Windows.Input.MouseButtonEventArgs)
   at System.Windows.UIElement.OnMouseLeftButtonUpThunk(System.Object, System.Windows.Input.MouseButtonEventArgs)
   at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(System.Delegate, System.Object)
   at System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object)
   at System.Windows.UIElement.ReRaiseEventAs(System.Windows.DependencyObject, System.Windows.RoutedEventArgs, System.Windows.RoutedEvent)
   at System.Windows.UIElement.OnMouseUpThunk(System.Object, System.Windows.Input.MouseButtonEventArgs)
   at System.Windows.UIElement.RaiseTrustedEvent(System.Windows.RoutedEventArgs)
   at System.Windows.UIElement.RaiseEvent(System.Windows.RoutedEventArgs, Boolean)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(System.Windows.Input.InputEventArgs)
   at System.Windows.Input.InputProviderSite.ReportInput(System.Windows.Input.InputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr, System.Windows.Input.InputMode, Int32, System.Windows.Input.RawMouseActions, Int32, Int32, Int32)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr, MS.Internal.Interop.WindowMessage, IntPtr, IntPtr, Boolean ByRef)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
   at System.Windows.Threading.Dispatcher.InvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
   at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
   at System.Windows.Threading.Dispatcher.Run()
   at System.Windows.Application.RunDispatcher(System.Object)
   at System.Windows.Application.RunInternal(System.Windows.Window)
   at System.Windows.Application.Run(System.Windows.Window)
   at System.Windows.Application.Run()
   at TestFGDB.App.Main()
LanceShipman
The API is not dependent on any of the ArcGIS libraries. You do need to have the Microsoft Visual C++ 2010 Run-time installed. Also be aware that the API can only open 10.0 file geodatabases.
ArtUllman
Thanks.  That explains it.  I ran a dependancy walker on the API DLLs and found that I was missing the Visual C++ Run in my deployment.  I added msvcp100.dll and msvcr100.dll to my deployment directory, and everything worked after that.  Thank you all of your help.
