Fillet Tool in Parcel Editor
1605
6
01-09-2012 08:39 AM
JohnFell
Occasional Contributor III
Does anyone know if there is an option for a fillet tool in the parcel editor tools?
ChrisBuscaglia
John, currently there is no fillet tool for Parcel Fabrics.  We're getting together some customer ideas for the next release, would you be willing to provide a more detailed example of the use-case for this tool?  Is this a cleanup routine?  For example, replacing a densified arc with a two-point curve?
Chris
JohnFell
All,
I have created an idea for this on http://ideas.arcgis.com/. I have listed a few examples where this tool might be useful. Please vote on this if you feel it might be helpful in your edit tasks at your organization.
WalidAlmasri
This would be useful when you need to construct a corner cut using a specific radius along two boundaries with no noted bearing.  Typically, these types of right-of-way takes assume the two boundaries are perpendicular to each other.  I'm having trouble in this too because there's no way to draw these properly without me using a 'construction' layer where I use the fillet tool to modify polylines, then note the COGO dimensions and traverse them in fabric. Trying to do this in fabric results in misclosures when they should be 0.000 in these instances.
ChrisBuscaglia
Walid -
For this operation, road cut or dedication:
1. Using a 'construct from parent' operation, create breaklines at 8ft along the easterly boundary and southern boundary respectively, add a chord by digitizing between the two breakpoints and entering a 8ft. radius into the grid for the new line.
2. Build and mark historic.
Chris
WalidAlmasri
Well, I just tried it and it worked.  That's awesome!  Thanks for the tip.  No way I would have figured that one out
But... it does cause a misclose.
ChrisBuscaglia
Walid - the mis-close may be a result of the original survey, typo, or the calculated (remainder) distances of the lines that you broke with the breakline tool.  Please check these dimensions in relation to the original lines.
