rename layers displayed on TOC
14968
13
01-10-2012 05:27 AM
FugroSurvey_Ltd_
I???m brand new to Python so I???m not sure if what I want to do is possible or not and I apologise for my lack of technical terms.
Basically I need to export a few files from ArcMap to CAD on a daily basis. As part of company procedures my CAD layers need to have a specific name which is different from the original GIS layer name. The problem is that the Export to CAD tool picks up the name displayed on the TOC to create levels' name in CAD.
Having said that what I'm looking for is to make a script to rename all the layers on my TOC. Is this possible?
I appreciate any help or pointers in the right direction.
PT
JakeSkinner
Esri Esteemed Contributor
Hi Y.Y.C,
You can do this using the ListFiles function.  Ex:
import arcpy
from arcpy import env
env.workspace = r"C:\temp\python"
for mxdFile in arcpy.ListFiles("*.mxd"):
    mxdPath = env.workspace + "\\" + mxdFile
    mxd = arcpy.mapping.MapDocument(mxdPath)
    layers = arcpy.mapping.ListLayers(mxd)
    for lyr in layers:
        if lyr.name == "something to change":
            lyr.name = "changed name"
    arcpy.RefreshTOC()
MathewCoyle
I think you want to access the arcpy.mapping.Layer(layer).name property.
See here http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s300000008000000
Here's a more complete example.
mxd = arcpy.mapping.MapDocument("current")
for lyr in layers:
arcpy.RefreshTOC()
Yaron_YosefCohen
Occasional Contributor II
how do it for 4 mxd's in one folder?
JakeSkinner
Hi Y.Y.C,
import arcpy
    for lyr in layers:
    arcpy.RefreshTOC()
Yaron_YosefCohen
thank's- it's worked!! how do i mark your answer as the right one?
RebeccaStrauch__GISP
I changed your "discussion" to a "question" and marked Jake's answer as correct for you.
Yaron_YosefCohen
now,i have mxd's and each of them has  3 and more data frame. if I wan't to rename layer  in  a specific data frame with position in the TOC, for example in the first data frame, how to do it ?
Yaron_YosefCohen
also i have this question Insert layer file to specific data frame
can you see it please?
DanPatterson_Retired
Branch multiple questions into individual ones and close the this thread by marking "helpful" or "like" to those that helped
Raphael_Augusto_FoscariniFerre
I put mxd.save() at the end of the script, to ensure keep the changing.
