CreateFeature : Class is not licensed for use (Exception from HRESULT: 0x80040112)
3614
01-10-2012 07:48 AM
RoobeshModi
We are trying to create a point into an existing point feature class using CreateFeature option. We are creating this in a Versioned geodatabase Arcgis 10
steps.
1. initialized ArcInfo license
2.opened workspace
3. Start an edit operation.
4. Performing edits
Public Shared Sub CreateFeature(ByVal featureClass As IFeatureClass, ByVal pnt As IPoint)
        Dim feature As IFeature = featureClass.CreateFeature()
        feature.Shape = pnt
        feature.Store()
    End Sub
5.Save the edit operation. To cancel an edit operation, the AbortEditOperation
We are getting error in step 4. at feature.Store() line.
The error message is :
we have a free ArcInfo license available during run time . But still we are getting the same error. Any help in resolving this problem is highly appreciated.
Thanks.
JakeSkinner
Esri Esteemed Contributor
Do you have ArcFM enabled for this geodatabase?  If you do, I believe you have to initialize the ArcFM license.
http://forums.esri.com/Thread.asp?c=93&f=993&t=183747
PallaviDubey
I am also facing the same issue while updating the feature. Everything goes fine until the code reaches feature.store().
It throws "Class is not licensed for use (Exception from HRESULT: 0x80040112)" error.
I have tried initializing the ArcFM license as well as suggested in above link. But it is not working for me. 😞
I m posting my code. Any help will be appriciated.
            IFeatureWorkspace pFeatureWorkspace = null;
            IWorkspace pWorkSpace = null;
            try
                pWorkSpace = GetWorkSpace(strSdeVersionName);
                pFeatureWorkspace = pWorkSpace as IFeatureWorkspace;
                // Open the feature class to rematch.
                IFeatureClass featureClass = pFeatureWorkspace.OpenFeatureClass(strFeatureClassName);
                IWorkspaceEdit workspaceEdit = pFeatureWorkspace as ESRI.ArcGIS.Geodatabase.IWorkspaceEdit;
                bool isBeingEdited = workspaceEdit.IsBeingEdited();
                if (isBeingEdited)
                    throw new Exception("Workspace is already being edited");
                workspaceEdit.StartEditing(false);
                workspaceEdit.StartEditOperation();
                try
                    ESRI.ArcGIS.Geodatabase.IQueryFilter pQueryFilter = (IQueryFilter)pSvrContext.CreateObject("esriGeoDatabase.QueryFilter");
                    pQueryFilter.WhereClause = strWhereClause;
                    ESRI.ArcGIS.Geodatabase.IFeatureCursor pFeatureCursor = featureClass.Search(pQueryFilter, false);
                    ESRI.ArcGIS.Geodatabase.IFeature pFeature = pFeatureCursor.NextFeature();
                    if (pFeature == null)
                        throw new Exception("Feature with " + strWhereClause + "could not be found/edited.");
                    while (pFeature != null)
                        foreach (KeyValuePair<string, string> keyValue in fieldValuePair)
                                pFeature.set_Value(pFeature.Fields.FindField(keyValue.Key), keyValue.Value);
                        pFeature.Store(); //Error is thrown at this line
                        if (UpdateOneFeatureOnly)
                            break;
                    if (pFeatureCursor != null)
                        System.Runtime.InteropServices.Marshal.ReleaseComObject(pFeatureCursor);
                    workspaceEdit.StopEditOperation();
                    workspaceEdit.StopEditing(true);
