Attribute Assistant INTERSECTING_FEATURE Problem
Discussion created by tmdeboer on Jan 31, 2012
Latest reply on Mar 23, 2015 by mmiller-esristaff
In my dynamicvalue table I have an entry for getting a value from an intersecting feature in a polygon layer. When I create/edit polygons, the intersecting feature works fine and gets the attribute value from the intersecting polygon, however when I try to edit/create points, it does not. However, this only seems to occur in SDE, when I try it with a file GDB it seems to work fine. Any thoughts? Thanks in advance!
