UnhandledException while trying to debug the simple MAP View Application
Discussion created by devendra.1.kumar on Feb 7, 2012
Latest reply on Jun 5, 2013 by aaa296609825
Hi All
There is strange problem in running the ArcGIS api for windows mobile.
Every thing is installed as per the stated guidelines on ESRI Resource center.
but when after install completion when i tried to make a simple map view application i followed the ways given on resource center.
everything seems to be fine on XAML as the compiler iis not prompting any error.
but when i am debuging it, its going to Unhandled Exception block.
the Detailed error retrieved from Exception Object is as followed:
Ist is MS.InternalWrappedException with message Could not load type 'System.Windows.FlowDirection' from assembly 'System.Windows, Version=, Culture=neutral, PublicKeyToken=7CEC85D7BEA7798E'.[/B
when i saw the internalException object for the above exception
then it was
System.MissingMethodException with message
Could not load type [B] 'System.Windows.FlowDirection' from assembly 'System.Windows, Version=, Culture=neutral, PublicKeyToken=7CEC85D7BEA7798E'.
My XAML File Is
    mc:Ignorable="d" d:DesignWidth="480" d:DesignHeight="768"
    FontFamily="{StaticResource PhoneFontFamilyNormal}"
    FontSize="{StaticResource PhoneFontSizeNormal}"
    Foreground="{StaticResource PhoneForegroundBrush}"
    SupportedOrientations="Portrait" Orientation="Portrait"
    <!--LayoutRoot is the root grid where all page content is placed-->
    <Grid x:Name="LayoutRoot" Background="Transparent">
            <RowDefinition Height="Auto"/>
            <RowDefinition Height="*"/>
        <!--TitlePanel contains the name of the application and page title-->
        <StackPanel x:Name="TitlePanel" Grid.Row="0" Margin="12,17,0,28">
            <TextBlock x:Name="ApplicationTitle" Text="GEOPROCESSING POC" Style="{StaticResource PhoneTextNormalStyle}"/>
            <TextBlock x:Name="PageTitle" Text="MAP VIEWER" Margin="9,-7,0,0" Style="{StaticResource PhoneTextTitle1Style}"/>
        <!--ContentPanel - place additional content here-->
        <Grid x:Name="ContentPanel" Grid.Row="1">
                <esri:Map x:Name="MyMap">
                    <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer"
    <!--Sample code showing usage of ApplicationBar-->
        <shell:ApplicationBar IsVisible="True" IsMenuEnabled="True">
            <shell:ApplicationBarIconButton IconUri="/Images/appbar_button1.png" Text="Button 1"/>
            <shell:ApplicationBarIconButton IconUri="/Images/appbar_button2.png" Text="Button 2"/>
                <shell:ApplicationBarMenuItem Text="MenuItem 1"/>
                <shell:ApplicationBarMenuItem Text="MenuItem 2"/>
I am very new to windows phone 7 development and i am just stucked due to this error.
I am at client side please help me that what exactly is required to do.
as i did everything as per the esri resource center.
Please reply at the earliest.
