Hi!
I created a table with several fields. Is it possible to change the type of number, i.e. from short integer to long integer once the field is created?! I cannot find how and where is the option to change it...
thanks in advance!
You can't. (Vote for the most popular idea to do this on the Ideas site here.) You have to create a new field and calculate over the old field values into it (best appraoch if ObjectID values cannot change) or create a new feature class, import the old schema, make the change prior to saving it, and load the data from the old feature class.
