ArcGIS Extensibility SDK for Silverlight installation issue
2890
02-13-2012 11:53 AM
JianChen
New Contributor III
I already successfully installed ArcGIS for Sharepoint. When I tried to install ArcGIS Extensibility SDK for Silverlight 2.4, I got an error saying "The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86(32-bit) or x64(64-bit) version of the program, and then contact the software publisher." What does this error tell me? Doesn't this extensibility SDK support 64-bit system? I couldn't find any document related to this issue. Any help is appreciated!
I'm running Windows 7 Professional and have Visual Studio 2010 and Sharepoint 2010. ArcGIS API for Silverlight 2.4 has been installed as well.
RahulMetangale1
Occasional Contributor II
Hi Jian,
Right click on setup file and select run as administrator. Most of the time this helps in resolving the installation related issue in windows 7.
Rahul
JianChen
New Contributor III
Hi Jian,
Rahul
Thanks Rahul, It seems not the case though.
When run it as administrator I got another error saying that Windows cannot find the file and ask me to make sure the name is correct and try again. This doesn't make sense because I right click the file and the file name cannot be wrong. Then I tried troubleshooting compatibility tools provided by windows 7 and the diagnose is that this file is compatible for Windows XP (Service Pack 2).
If this is true, is there any 64-bit compatible version of this Extensibility SDK? Thanks!
WilburHughes
Try downloading the SDK setup again. The error seems to indicate that the file is corrupt because you received Windows error message "this file is not compatible with the version of Windows you're running". The setup never seems to have run and there is not a check in the setup for the Operating System.
JianChen
New Contributor III
Thanks Willbur!
You're right! There is no signal for me that this file is corrupt. I re-download it again and this time it works. Thanks!
