Performing some mathematical transformations in Geostatistical Analyst
1069
02-20-2012 03:56 AM
OrhanGUNDUZ
Hi guys:
I need to perform some simple mathematical transformations on my cokrigged surface within Geostatistical Analyst. I know this is doable after the surface is exported as a grid and processed in Map Algebra. But I want to stay inside GA and do my computations within the tool.
Anybody got any idea?
Orhan
EricKrause
The back-transformation needs to be built into the kriging step.  You can't simply apply a transformation, perform kriging, then apply the back-transformation to the results.  In other words, you should stick to the transformations that we've developed and integrated into the kriging: Log, Box-Cox, ArcSin, and Normal Score.
The Normal Score is the most functional type:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00310000000v000000.htm
For ArcGIS 10, Gaussian Kernels is the most functional approximation type for Normal Score Transformation.
