Connecting to Secured Services on arcgis.com for Organizations
619
02-22-2012 10:40 AM
RandyHauser
New Contributor III
It would seem that it's not possible to add a feature service (from arcgis.com) as a layer to your map if it is only shared with your organization (yes, using the beta).  I get a "Unable to connect to <service URL>" error when I attempt to add the layer.  Is it possible to somehow have authentication on the Silverlight side that passes through authentication to arcgis.com to allow access to that feature service?
RandyHauser
New Contributor III
I understand that you can use token for secured services if you're using the API, but I'm not seeing where this may be implemented using the Viewer.  Is this a planned feature or am I just missing it?
KatherineDalton
Hi Randy,
It's a similar scenario with the Viewer as with the API. See Adding" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/help/inde... secured services and Configuring" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/help... a proxy for information. Please let me know if you have additional questions on this.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
