I am working with GWR and can run it fine, however I am having problems with the results and what exactly to map.
First of all just to check, the results titled C1, C2 and so on are the explanatory variable coefficients? Are these coefficients the coefficients of determination for each independent variable or something else? Also, I've been reading around the subject and finding out what is best to actually map to go into my reports, are these the explanatory variable coefficients best to map or I've read about dividing the explanatory variable coefficients by the standard errors to get the t-value to map.
Sorry it this is very simple, I am new to ArcGIS and regression! Any advise would greatly be received. Thank you 🙂
