How to zoom in beyond basemap's maximum zoom
8440
9
03-04-2012 01:51 AM
PatrickTierney
I'm trying to display a dataset with a higher resolution than the Bing Map basemap, my current basemap. When I try to zoom in to see more detail, the map zooming stops, presumable because the Bing map doesn't support zooming in that much. Is there a way around this to allow me to zoom in beyond the level Bing maps supports? I don't mind if image quality degrades.
Patrick
NimeshJarecha
Here is how I would test this...
1. Create a tiled map service which supports LODs below Bing Map. Bing Map's lowest scale of 1128 so create a tiled cache with 1000,500 and 250 scales. Make sure that the this tiled layer is in Web Mercator spatial reference.
2. Add Bing Map to the map first.
3. Add AGSTiledMapServiceLayer (not custom tiled layer for testing purpose) created in step 1 on top of Bing Map.
4. Now on map keep zooming in and it should allow zooming beyond 1128 scale.
I tested this and it just works.
Regards,
Nimesh
NimeshJarecha
The best option is to add one more tiled layer (make sure that it has same spatial reference as bing map) which supports the level you want to view (below bing map's last level).
Regards,
Nimesh
PatrickTierney
Sorry for revisiting this old thread, though after several weeks of trying I still haven't figured out how to zoom in past a basemap's maximum LOD/zoom. I've tried implementing a custom AGSTiledLayer with a higher LOD than the BingMap, though I still can't zoom in enough. If you have any experience adding more detailed layers to a base may I would certainly appreciate any examples.
I've attached an example of my detailed layer.
Many thanks,
Patrick
NimeshJarecha
Regards,
Nimesh
PatrickTierney
Hi Nimesh,
I finally got it working using a modified version of my previous code -- using a AGSTiledLayer and a dummy tile retrieve operation. I didn't want to spend time making another map on the server, I simply wanted the bing map to zoom in slightly more. It's probably a hack but it works...
Thanks again for the help,
Patrick
NimeshJarecha
Great! Finally you got it working! 🙂
Regards,
Nimesh
SimonJackson
Occasional Contributor III
Is this the best way to achieve this? From a Flex and Javascript API perspective, adding LODs was part of the API.
Specify LODs (levels of detail) | ArcGIS API for JavaScript
Was hoping for a similar method on the AGSMapView.
by Anonymous User
Not applicable
Nimesh solution is probably the best, here is another idea :
You can change the maxScale of the map itself and the layer to zoom beyond the tile and stretch it.
Listen for the basemap did load and do it inside the delegate
AGSTiledMapServiceLayer *basemap = [AGSTiledMapServiceLayer tiledMapServiceLayerWithURL:url]; // or bing, whatever you like
    basemap.delegate = self;
    [self.mapView addMapLayer:basemap withName:@"basemap"];
- (void)layerDidLoad:(AGSLayer *)layer
    layer.maxScale = 0;
    self.mapView.maxScale = 10;
Hope this helps
Cheers
Al
JoeWong1
Al,
I used the following code:
self.mapView.maxScale = 10 and was able to zoom in beyond the ArcGIS Imagery Basemap.  However, the issue that I am having is that when I zoom in beyond the imagery basemap, the basemap disappears.  Is there a way to keep the basemap within the mapView even if it is distorted?
A co-worker of mine said that that was possible but I haven't been able to get it to work.
thanks,
Joe
DiveshGoyal
You will need override the max scale property of the imagery basemap layer. Otherwise it will turn off if you zoom in beyond the max scale.
