How could I bind the shape attributes to rules attr in python script
2997
03-06-2012 10:56 PM
gouzhun
HI, I want to batch export my model from cityengine without setting attr in UI,but in the py script I don't know how to bind the shape attr to rules attr.
please help!
thanks!
gouzhun
Tags (3)
MatthiasBuehler1
I'm not perfectly sure if I understood correctly, but I gues this is what you need :
    ce.setAttributeSource()
check the Help Menu for the Python docs under :
CityEngine Help > Python Scripting > Scripting Interface Usage > Commands by Category
and search for that command.
does this work ?
MatthiasBuehler1
does this work ?
gouzhun
does this work ?
Yes!
With your suggestion,I've solved the problem smoothly,thanks for your help,matthiasbuehler!
gouzhun
