plambert75
Deriving block parameters from landuse maps
Discussion created by plambert75 on Mar 7, 2012
Latest reply on Mar 13, 2012 by MBuehler-esristaff
Is it possible to use a landuse map to set various block subdivision parameters? I have different landuse types in my city (e.g. residential, highrise, industrial) defined in a texture map but the block parameters for each landuse type need to be different. For example, the residential blocks need to be subdivided into smaller lots than the industrial lots. I'd like to use the landuse map to define how to subdivide the blocks rather than having to select them manually in CityEngine if possible.
Outcomes
