Identify Route Location Widget?
5175
20
03-08-2012 11:02 AM
MichaelMiller2
Occasional Contributor III
Afternoon all,
Anyone know if there has been any work done on a widget that functions like the dynamic segmentation "Identify Route Location" tool in ArcMap?
I have some users who would like to be able to click on a route and identify the measure for that location.  I'm rather new to Flex and am just starting to jump into writing code.  Any ideas or help would be much appreciated.
Michael Miller
nicogis
MVP Frequent Contributor
MichaelMiller2
you need do only widget: I have made a soe for this functionality.
http://resources.arcgis.com/gallery/file/arcobjects-net-api/details?entryID=46F00F42-1422-2418-7F40-...
Cool.  I'll look into using this in a widget.
Thank you for posting your code.
Michael
TerryGustafson
Did the code he recommended work?  the link is broken so was wondering if I could get it from you?
Terry
nicogis
This is new link: http://www.arcgis.com/home/item.html?id=e3bfa7c991e34aa8872c937ca9169507
If you need a complete solution you can see Roads and Highways of Esri Roads and Highways | ArcGIS Resource Center
TerryGustafson
When I browse to the soe to try and add the extension I click add but it does not add the extension. Is there a trick or am I missing something?
TerryGustafson
Would the problem be that I’m using 10.2.2?
nicogis
What's the browser that you are using? If you use IE with ESC enabled you have this problem
TerryGustafson
I tried it on both IE and chrome and Firefox. I did receive the following error in Firefox. I tried to load the SOE from the 102/SOE/bin/release folder. The “Studioat.ArcGis.Soe.Rest.DSUtility.dll” file is in the same folder as the soe. Do I need to maybe open the project in Visual Studio and register that dll?
nicogis
Studioat.ArcGis.Soe.Rest.DSUtility.soe is a zip file so you can rename and see if there is the dll.
you must not register dll
when do you install ags have you checked also support .net extension ?
