ArcGIS API 3.0 Prerelease for Flex released March 19, 2012
878
11
03-19-2012 09:14 PM
BjornSvensson
The new API community site:
resourcesbeta.arcgis.com/en/communities/flex-api/
What's new in ArcGIS API 3.0 Prerelease for Flex
http://resourcesbeta.arcgis.com/en/help/flex-api/concepts/index.html#/What_s_new_in_ArcGIS_API_for_F...
Note that the URLs have changed slightly from the 3.0 beta.  We will remove those pages later this week.
MatthewGubitosa
New Contributor III
Does pre-release 3.0 require Adobe FlashBuilder < 4.5?  I am having trouble compiling with 4.5 - lots of errors
See attached for screenshots[ATTACH=CONFIG]13321[/ATTACH]
BjornSvensson
I am having trouble compiling with 4.5 - lots of errors[ATTACH=CONFIG]13321[/ATTACH]
3.0 Prerelease only works with 4.5 and above.
I think in your case, maybe you have not added the API Library (the SWC file) yet?  You need to download it separately - http://links.esri.com/flex-api/latest-download.
See http://resourcesbeta.arcgis.com/en/help/flex-api/concepts/index.html#/Getting_started/017p0000001q00... for how to include it in your project.
MatthewGubitosa
New Contributor III
I extracted agslib-3.0b1-2011-12-16.swc from arcgis_api_for_flex_3_0.zip and placed it into the libs folder of ArcGIS-ArcGISViewerForFlex-flexviewer-3.0Prerelease-src-0-g16b7ba8.zip
This resulted in a reduced number of compile errors (25), but not zero.
[ATTACH=CONFIG]13355[/ATTACH]
BjornSvensson
agslib-  3.0b1-2011-12-16.swc ... flexviewer-  3.0Prerelease-src
That's the "3.0 beta 1" SWC. Try with the "3.0 Prerelease" SWC instead: http://links.esri.com/flex-api/latest-download
DerekHunter
Could anyone suggest the tag and tag location used to enable the basemap thumbnails beyond the default defaultBasemapIcon.png?
RobertScheitlin__GISP
Derek,
   Are you talking about the Flex Viewer's MapSwitcher?... Because you are posting to the AGS Flex API forum post announcement for the 3.0 pre release API... Maybe you are looking for this documentation from the Flex Viewer 3.0 pre release:
http://resourcesbeta.arcgis.com/en/help/flex-viewer/concepts/01m3/01m300000026000000.htm
DerekHunter
Yes..sorry I mistakenly thought I was creating a thread rather than a reply to the pre-release announcement.  Your link is what I was looking for.  I will delete and repost.
Hubo
Good forum. I like to solve problem in this forum.
SarahBurgin
Just tried 3.0 pre-release with our applications. I came across an issue of the 'GraphicsLayer' class no longer having 'units' as an attribute but don't think this change is mentioned in the release note?
