Rules for distance of parcel limit at Building
352
03-30-2012 01:56 PM
TadeoSanabria1
Hello
Excuse my bad english
I'm working on a urban model derived from the town planning regulations.
I required to establish differential distances between the boundary of parcel and the limit of each side of the building
I tested with the offset command but applies the same distance from all faces, but I need to differentiate between the face and apply a distance
What command should I use, or what is the proper rule?
There is some learning resource CityEngine in Spanish, or any forum in this language?
I appreciate any help. Thanks.
AndréCardoso
New Contributor III
You can use the setback operation, in a recursive manner.
I think any solution depends on some more details of your problem...
The solution I provide bellow does not seem very elegant, nor it works in every situation... but it might get you going for now... 🙂
[ATTACH=CONFIG]13159[/ATTACH]
version "2011.2"
attr buildingHeight = 10
attr buildingColor = "#4A708B"
attr leftColor = "#FF0000"
attr rightColor = "#0000FF"
attr backColor = "#FFA500"
attr frontColor = "#800080"
attr frontSetback = 2
attr leftSetback = 8
attr rightSetback = 4
attr backSetback = 10
@StartRule
LotInner -->
    NIL.
@StartRule
LotCorner -->
    NIL.
@StartRule
Lot -->
    setback(frontSetback){
        front: color(frontColor) FrontPart.|
        remainder: MinusFront
MinusFront -->
    setback(leftSetback){
        left: color(leftColor) LeftPart.|
        remainder: MinusFrontAndLeft
MinusFrontAndLeft -->
    setback(rightSetback){
        right: color(rightColor) RightPart.|
        remainder: MinusFrontLeftAndRight
MinusFrontLeftAndRight -->
    setback(backSetback){
        back: color(backColor) BackPart.|
        remainder: MinusFrontLeftRightAndBack
MinusFrontLeftRightAndBack -->
    Mass
Mass -->
    alignScopeToAxes(y)
    extrude(world.y, buildingHeight)
    color(buildingColor)
    Mass.
I don't know any documentation in spanish though :S
I normally use the application help menu window, and this forum 🙂
Hope it helps!!
TadeoSanabria1
Thanks, i'll try to base me in your solution and then i comment the results.
