Creating Seamless Raster Mosaic
4731
6
04-02-2012 12:25 PM
KaileyCooper
I used the "Mosaic to New Raster" tool to create a mosaic of DEM's.
Now I want to make them seamless so I can do watershed analysis on them. I am using ArcGIS 10 and the code I was given to use in the Raster Calculator is not working.
I got the code from this video: http://www.youtube.com/watch?v=qJHCbEVbMv0
They appear to be using an older version and have a code for ArcGIS 10, but that is not working either.
These are the codes I was given:
Con(IsNull(â??myrasterâ?�),FocalStatistics(â??myrasterâ?�,NbrRectang¬le(2,2),â?�MEANâ?�),â?�myrasterâ?�) - this is for ArcGIS 10
[seemless] = con(isNull([mosaic]),focalmean([mosaic],rectangle,2,2),[mosaic]) - this is for the older version. [seemless] would be the name of the file I am generating and mosaic is the file I already created.
Do you have any suggestions on making this work? Much appreciated!!
TarunJaiswal
Greetings!
Please try the following syntax:
Con(IsNull("myraster"), FocalStatistics("myraster", NbrRectangle(2,2, "CELL"), "MEAN"), "myraster")
Also, here is a link to a Knowledge Base - Technical Article on this subject
Remove and replace no data values within a raster using statistical information from the surrounding...
Hope this helps.
Thank you.
DarrenWiens2
MVP Honored Contributor
NbrRectang¬le(2,2)
Is there really a strange character in there?
KaileyCooper
Thank you so much!
That worked - saved me so much more stress! 🙂
KaileyCooper
No - It must have done that when I copied it. oops!
KaileyCooper
Greetings!
Hope this helps.
Thank you.
Thank you so much!
DarrenWiens2
Greetings!
Tarun, the only difference between your statement and cooperkn's is the additional of the units parameter ("CELL"), which is clearly labelled in the help pages as optional. Is this, in fact, not optional? If so, how does a person report errors in the help documentation?
edit: nevermind, I found the feedback button. We'll see if it gets changed.
