eTime Widget time interval problem
1469
17
04-05-2012 03:07 PM
RhettZufelt
MVP Frequent Contributor
Below is the MapService time info for my "layer":
Time Info:  Start Time Field: Year_of_Trans End Time Field: N/A Track ID Field: N/A Time Extent: [2010/01/01 08:00:00 UTC, 2015/01/01 08:00:00 UTC] Time Zone: Pacific Standard Time    Respects Daylight Saving: False Time Interval: 1 (esriTimeUnitsYears) Export Options:   Use Time: True Time Data Cumulative: False Time Offset: 0
My Year_of_Trans field only has 4 digit years from 2010 to 2015.  In ArcMap, the time slider, set to 1 years interval will step through 1 year at a click/slide.
However, in the FlexApp, for the first three years, there are two clicks/slides per interval and in the last two years, there are only one.  (I.e., starts by displaying the 2010 data, to get to display 2011 data, need to click on the next arrow TWICE.  Same for 2011-2013.  Then, there is only 1 click for 2014 and 2015).  Also, the only values in my time field is the 4 digit year, yet somehow, when you "slide" the slider, it is putting in months, day, year and even time???  Not sure how/where it is interpolating that information from, but is probably related to my issue.
Does the eTime slider only work with time fields of a particular type or is it supposed to work with same types as ArcMap slider?  I started with a date field type, but could never get just a 4 year only to go, so have tried with both numeric and text fields, but have the same issues with all.
Any ideas?
R_
RobertScheitlin__GISP
Rhett,
  Here is the updated uncompiled version. See if this addresses the issue you are having.
RhettZufelt
Bump, and more on this.
It appears as if this is not an eTime widget issue, but a Time widget issue in general.
Does not matter if I load the eTime or Time widget, it is still appears to be "creating" time sequence data on it's own.
I am used to server changing config files on it's own, but can't figure out where these extra time "intervals" are coming from, but they don't appear in ArcMap.
R_
RhettZufelt
R_
guess it is an eTime widget issue afterall.  I can configure the Time widget to increment by year with only one stop per year.  However, if you drag the slider, it is still putting time/date info in there from somewhere.
However, the eTime widget, no matter how I try to configure it, seems to automatically break each interval into "two" stops.
rhett,
  The lieklyhood of this being related to the eTime is very slim. The eTime is identical to the time slider widget except for the fact that it allows you to specify a different layer at runtime. The routine for determining the time extent is unchanged in the eTime widget from what it is in the esri time slider widget. I actually don't work alot with time enabled layers so I don't really know how you can use a field with just a year and get it to work properly.
RhettZufelt
Thanks for the info.  Still can't figure out what is going on here.
Here is my timewidget_config:
<?xml version="1.0" ?>
<configuration label="2015 Visiontest">
    <dateformat>YYYY</dateformat>
    <loop>true</loop>
    <singlethumbastimeinstant>true</singlethumbastimeinstant>
    <thumbcount>1</thumbcount>
    <thumbmovingrate>1500</thumbmovingrate>
    <timeextent setfromlayer="2015 Visiontest"/>
    <timestops>
        <timestopsinterval>1</timestopsinterval>
        <timestopsunits>years</timestopsunits>
    </timestops>
</configuration>
and here is the eTime widget_config:
<configuration>
      <layers>
  <layer label="Year Of Transition" name="2015 Visiontest">
      <loop>true</loop>
      <timestops>
      </timestops>
  </layer>
    </layers>
</configuration>
Seems like they should be working "the same", but they are not.  The Time widget is giving me ONE interval per year (each time I move the slider one "click", it increments it one year).  With this same config, the eTime widget is giving me TWO intervals per year (have to move the slider two "clicks" in order to increment one year).  Both are using the same time enabled service, yet behave differently.
Do you see anything that I'm missing here?
Thanks again,
Rhett
Rhett,
   I don't suppose your map Service is pubic for me to access is it? If not would you give me all the details about the layer (field types, values, etc) so I can re-create the map service?
Rhett,
  Are you using the compiled or the uncompiled version? I believe I found a mistake in my code:rolleyes: and I would like you to see if it fixes the issue you are seeing.
RhettZufelt
Unfortunatly,  my services are not available publicly.
Here is what my polygons look like: [ATTACH=CONFIG]13782[/ATTACH]
I have two attribute columns.  One is a text column of length 20 and the other is a short column length 2.  Both have a 4 digit year between 2010 and 2015 and each polygon only has one year assigned.  The idea is to have only the polygons with the respective year to display as you move the slider.  I have tried using both of these columns and have the issues.  With the Time slider, I got it to work using the text column as the time field.  Well, it "works" with the eTime also, just gives me the two steps per interval issue.
I am using the un-compiled version so can do any testing needed.  Right now, I am actually using the pre-release3, but, to make sure it wasn't related to that, I have also set it up in the 2.5 version and have the same results.
Here are the rest attributes for my service (minus the symbology info to reduce size):
Layer: TA (ID: 0)
Display Field: Year_of_Trans
Type: Feature Layer
Geometry Type: esriGeometryPolygon
Description:
Definition Expression:
Copyright Text:
Min. Scale: 0
Max. Scale: 0
Default Visibility: True
Extent:
XMin: 558473.4375
YMin: 113834.0086
XMax: 594972.687500002
YMax: 154573.8906
Spatial Reference: 32149
Has Attachments: False
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Time Info:
End Time Field: N/A
Track ID Field: N/A
   Respects Daylight Saving: True
Export Options:
Use Time: True
Time Offset: 0
Fields:
OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID)
Shape (Type: esriFieldTypeGeometry, Alias: Shape)
Shape_Length (Type: esriFieldTypeDouble, Alias: Shape_Length)
Shape_Area (Type: esriFieldTypeDouble, Alias: Shape_Area)
Year_of_Trans (Type: esriFieldTypeString, Alias: Year_of_Trans, Length: 20 )
time2 (Type: esriFieldTypeSmallInteger, Alias: time2)
Type ID Field: N/A
Thanks again for looking into this Robert,  let me know if I can test anything or answer any other questions that may help,
Rhett
Rhett,
RhettZufelt
That did the trick.
Thanks again for your timely solution.
Also, I modified this line in the TimeSliderSkin.mxml
<mx:DateFormatter id="dateFormatter" formatString="MMM D, YYYY at L:NN A"/>
to
<mx:DateFormatter id="dateFormatter" formatString="YYYY"/>
Now it no longer makes up a day and time when moving the slider manually.  Only shows the year as in the time field.
I tried to figure out how to use an If format == "YYYY" then formatString="YYYY", that way, it would be more robust to other layers/maps.  However, for this map, the only time enabled layers are by 4 digit year only, so a mod to the skin.mxml works fine.
Thanks again,
Rhett
