ArcGIS Extensibility Issue.  I'm sure simple fix.
3227
16
04-06-2012 10:02 AM
deleted-user-yA_w_FC9FKe5
New Contributor III
I have Visual Studio 2010 and I have installed the 1.0.1 Silver light viewer for ArcGIS.  I wanted to try and create some add-ins but I am having issues.  I've installed both of these:
ArcGISExtensibility2_4__en
ArcGISSilverlightViewer1_0_1_x64_en
However, when I go to VS2010 and click on File/New/Project/Other Languages/Visual C#/Silverlight/ I only have these options:
Silverlight Application
Silverlight Class Library
Silverlight Navigation Application
I do not see anything ESRI.  What am I doing wrong?
BrianLeroux
Occasional Contributor III
Here is a screenshot so you can see where the template can be found. If you expand silverlight and do not see the ESRI Viewer option than I am not sure what is going on. I have the ESRI Silverlight API installed. The Silverlight Viewer Installation guide doesn't say it is needed but i never tried without.
[ATTACH=CONFIG]13350[/ATTACH]
KatherineDalton
Hi Michael,
To start, can you uninstall and reinstall the Extensibility SDK? Also, the ArcGIS API for Silverlight is included when you install the Extensibility SDK, so you don't need to install that separately.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
New Contributor III
Hi Michael,
Katy
Katy:  Which one of these do you want me to uninstall?  Do you want me to use the add/remove to do this?
[ATTACH=CONFIG]13452[/ATTACH]
This is all I see in Visual Studio 2010.  BTW I have the professional and am using Windows 7 with 64 bit.
[ATTACH=CONFIG]13453[/ATTACH]
KatherineDalton
Hi Michael,
Go ahead and uninstall both the ArcGIS Extensibility 2.2 and ArcGIS Extensibility SDK for Silverlight 2.4. Use Add/Remove programs for this. Then reinstall the ArcGIS Extensibility SDK for Silverlight 2.4.
Let me know how that goes.
Katy
New Contributor III
Hi Michael,
Katy
It went bad as I have the same results.  Any other thoughts?
New Contributor III
I still have not seen a fix.  Can anyone help please?  Would like to get moving on this project.
GerardoGarza
New Contributor III
Hi Michael,
Do you happen to have your Visual Studio in a non-default location, instead of C:\Program Files\?
If so, then take a look at http://forums.arcgis.com/threads/48114-Issues-with-2.4-Extensibility-Kit-Installation .
Hope this helps.
GG
KatherineDalton
Hi Michael,
As mentioned by Gerardo, is there any chance your Visual Studio installation is not in the default location? This is a known issue, and if it is the case we can help you with the workaround.
Katy
New Contributor III
Yes I think it is.  How can I fix this in as few as steps as needed?
E:\Visual Studio 2010 VB Web\Silverlight
Also I am heading to the ESRI conference and was hoping they might have just a training session for the Silverlight viewer.  I see they have one for Silverlight.  Will that be useful to me.  I'm deciding between Silverlight and Flex right now.  They both have their good and bad qualities.  I like the ease of use of Silverlight to do little things to the layers like the popups/symbology etc. . .  I just wish I could do a bookmark like I can in Flex to have the user be able to zoom to an area quickly.  I guess another post.
<configuration label="Bookmarks By District">
    <bookmarks>
    <bookmark name="No District">-13621978.5351572 4048248.28920286 -13117537.5619596 4484563.72890677</bookmark>
  <bookmark name="Arizona">-12492907.7779187 3680924.6783104 -11842169.6569783 4243779.60972175</bookmark>
  <bookmark name="Atlanta East">-9391173.84412393 3744417.78139386 -9030028.92570257 4056789.52011089</bookmark>
  <bookmark name="Atlanta West">-9663383.39496072 3780856.45279004 -9316724.48187629 4080698.54359193</bookmark>
  <bookmark name="Bay Area North">-13662227.7467196 4561810.13963013 -13563462.868098 4647236.66866469</bookmark>
  <bookmark name="Bay Area South">-13595049.7736106 4326078.7663508 -13282157.4016685 4596714.53960793</bookmark>
  <bookmark name="BLM">-13626330.5505235 -4304906.60586656 6153648.72191633 12803755.8782334</bookmark>
  <bookmark name="BLMO">-10141232.660216 2972862.27595857 -7602441.84001575 5168785.46992559</bookmark>
  <bookmark name="Chicago North">-9963072.80226241 5137898.4852809 -9749024.17865012 5323039.51127132</bookmark>
  <bookmark name="Chicago South">-9828204.3605927 5081627.48323646 -9719349.05458848 5175781.71183186</bookmark>
