odd behavior of using group data  from an account outside of organization
329
04-09-2012 01:10 PM
ClemHenriksen
HI,
I have some data I want to enable for simple attribute edits. the catch is that the data is produced inside an organization, but i dont want to include the account doing the editing in the organization. I set up a test.
I tried to limit access to the data by creating a group, sharing the feature service, the web map, and the web application in the group. I invited a non-organizational account to the group. thus, i am attempting to use the group permissions to limit access to the data, regardless of the organization.
from the non organizational account, i accepted the group invitation, then accessed the data. The feature service, the web map, and the web application were all displayed in the group. I double-clicked the web app, then attempted to view application.
the web app starts to load, then I am thrown to the login screen.
I tried to access the group data from an organizational account and was able to do so.
Should I be able to access data in an organization from an account not in the organization through group permissions?
thanks.
MikeMinami
Esri Notable Contributor
Did you try signing in when prompted with the non-org login? Did it fail?
Mike
ClemHenriksen
I did try, and it failed in the usual way where I get a confusing message.
not trying to be argumentative... I have gotten the same confusing message before in other contexts. I think it has to do with multiple simultaneous logins on the same web browser instance (Mozilla in this case). I typically fix this message by starting a new browser window. new browser tab is not sufficient to make confusing error message go away. I think this may have to do with me having multiple accounts that use the same email address.
at any rate I am mystified as to why it would want me to log in when I am already logged in and why it would want me to log in when what I have asked it to do is launch an app.
ClemHenriksen
OK, another stab at it.
created a new acct thru the organization admin tools, then accept the invitation to join.
invited new acct to join group, accepted group invitation.
from new acct was able to launch and use web app. Success.
but the original problem still bugged me so I tested a bit more.
1) start with being logged in as new acct.
2) sign out, then sign in as non-org acct.
3) as non org acct, but member of group, attempt to launch web app
4) same behavior as before- on launch throws me to login panel with error message 'The resource you are trying to reach requires you to sign in.'
5) now in endless loop unable to login
6) open new tab, sign in as non-org acct successfully. attempt to launch web app with same behavior as above, ending in endless login loop.
my previous statement stands corrected - you can retry with a new tab, a new browser instance is not required. However, still seems like a software anomaly to me...
sooo, it seems that in order to use a web app created in an organization, your login must be part of that organization. Correct?
thanks.
clem
