ReferenceLink does not change after an update!
Discussion created by c.hufmuelleresri-de-esridist Employee on Apr 9, 2012
Latest reply on Apr 13, 2012 by RAnderson-esristaff
I have a problem with node-on-links!
I build a railroad network in schematics. The rail can have a signal as node-on-link. The field REFERENCELINK in the node-on-link, in which must stand the SchematicID from the rail, is taken out from a field called �??SchematicGleisID�?� also in the node-on-link. The generation of the schematic works great and the REFERENCELINK has the same SchematicID as well as the field �??SchematicGleisID�?�. But when I change the SchematicID in the field �??SchematicGleisID�?� and I update my schematic, the REFERENCELINK does not change its ID!!! What can I do so that the REFERENCELINK will change after an update?
Thanks for any help!
