ArcGIS Web Maps - Embed question
513
04-11-2012 12:03 PM
PaulStahlschmidt
I've embedded my map in a website and it appears very zoomed-out. When I save the map on the ArcGIS page at a zoomed-in level it does not appear that way on the embedded site. Is there any way to fix this? I have looked at the HTML codes and cannot find a way to adjust this.
Thanks for the help.
MikeMinami
Esri Notable Contributor
Can you post the embed code of your map here? Embedding should use the current visible extent of the map when you generate the embed code.
Mike
PaulStahlschmidt
Mike, I deleted the codes and started over and its working now.  Thanks.
