Geocode then query a layer using the result
2349
04-12-2012 02:49 PM
SandeepTalasila
New Contributor III
I am trying to implement query functionality in the Locate Widget in Flex viewer 2.5. I want to geocode an address and then use the point to perform a identity / query on a different layer, and the result window should display the geocoded result along with the identity / query attributes. Could anyone guide me on how to implement the query task in the locate widget?
I found a thread which address the same and also a flex application by Robert with the same functionality, but am not successful yet to make it work in flex viewer 2.5. I would appreciate any thoughts.
http://forums.esri.com/Thread.asp?c=158&f=2421&t=287256#892446.
http://gis.calhouncounty.org/SchoolDistricts/
RobertScheitlin__GISP
Sandeep,
   I don't have anything that is just copy and paste ready but in your referenced links you have all the basics that a developer would need to get going on thier own. Also here is antoher example of using the locate widget to send the location to the identify widget.
http://forums.arcgis.com/threads/47883-Using-the-Locate-Widgets-results-to-populate-the-datagrid-in-...
I just don't have time to write the code for you.
SandeepTalasila
New Contributor III
Thank you for the help Robert. I will give it a try.
