Populate an existing popup with an AttributeInspector after RelationshipQuery returns
1942
04-14-2012 12:56 PM
KyleBelott
Here's the workflow: A user selects a feature layer polygon, views a popup. A link added to the popup will run a RelationshipQuery to view related records. How can I get the RelationshipQuery results to update the first popup as an AttributeInspector? A second link on the first popup would run a function to add a new record to the related table, that would also need to appear as an AttributeInspector in the first popup. I don't think I'm handling the RelationshipQuery results correctly because the second popup comes back with 'no features selected'. I've run the Query Related Records on the REST feature service so I know the relationship is established.
Thanks much for any input
B
dojo.require("dijit.form.Button");
dojo.require("dijit.Toolbar");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.TitlePane");
dojo.require("esri.map");
dojo.require("esri.toolbars.navigation");
dojo.require("esri.dijit.BasemapGallery");
dojo.require("esri.arcgis.utils");
dojo.require("esri.dijit.Popup");
dojo.require("esri.dijit.AttributeInspector-all");
var popup, popupTemplate;
var startExtent;
var map;
var gallerymaps = [];
var featureLayer, basemapGallery, HybridLayer, ImageryLayer, BasemapLayer, operationalLayer;
var HybridBasemap, ImageryBasemap, BasemapBasemap;
var selectionHandler;
var query,relatedQuery;
var deferred = [];
var viewLink, newLink;
function init() {
esri.config.defaults.map.sliderLabel = null;
popup = new esri.dijit.Popup({
fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new dojo.Color([0, 0, 255]), 2), new dojo.Color([0, 0, 255, 0.25]))
}, dojo.create("div"));
startExtent = new esri.geometry.Extent(...);
map = new esri.Map("map", {
extent: startExtent,
infoWindow: popup
dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
dojo.connect(map, "onClick", function (evt) {
query = new esri.tasks.Query();
query.geometry = evt.mapPoint;
deferred.push(featureLayer.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW));
map.infoWindow.setFeatures(deferred);
map.infoWindow.show(evt.mapPoint);
map.infoWindow.resize(325, 210);
relatedQuery = new esri.tasks.RelationshipQuery();
relatedQuery.outFields = ["*"];
relatedQuery.returnGeometry = false;
relatedQuery.relationshipId = 0;
// Add links into the InfoWindow Actions panel
viewLink = dojo.create("a", {
"class": "action",
"innerHTML": "View Activity",
"href": "javascript:void(0);"
}, dojo.query(".actionList", map.infoWindow.domNode)[0]);
newLink = dojo.create("a", {
"class": "action",
"innerHTML": "Add Activity",
// Register a function to be called when the user clicks on the link
dojo.connect(viewLink, "onclick", function (evt) {
var feature = map.infoWindow.getSelectedFeature();
exeViewRelated(feature);
dojo.connect(newLink, "onclick", function (evt) {
exeAddRelated(feature);
dojo.connect(featureLayer, "onEditsComplete", function () {
featureLayer.refresh();
addFeatureLayer();
//working around an arcgis server feature service bug
esri.setRequestPreCallback(function (ioArgs) {
if (ioArgs.url.indexOf('queryRelatedRecords') !== -1) {
ioArgs.url = ioArgs.url.replace("FeatureServer", "MapServer");
return ioArgs;
return map;
function addFeatureLayer() {
//add the operational layer to the map
operationalLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://.../MapServer");
map.addLayer(operationalLayer);
popupTemplate = new esri.dijit.PopupTemplate({
title: "{PHYISICALADDRESS}",
fieldInfos: [
{ fieldName: "PARCELNO", visible: true, label: "Parcel Number:" },
{ fieldName: "OWNERNAME", visible: true, label: "Owner Name:" },
{ fieldName: "MAILADDRESS", visible: true, label: "Mailing Address:" },
{ fieldName: "MAILLOC", visible: true, label: "Mailing Location:" },
{ fieldName: "CONTACT_PHONE_NUMBER", visible: false, label: "Phone Number:" },
{ fieldName: "CONTACT_EMAIL", visible: false, label: "Email Address:" },
{ fieldName: "ACTIVITY_DESIGNATION", visible: false, label: "Designation:" },
{ fieldName: "ACTIVITY_DATE", visible: false, label: "Activity Date:" },
{ fieldName: "ACTIVITY_INFO", visible: false, label: "Activity Information:" },
{ fieldName: "ACTIVITY_CUSTODIAN", visible: false, label: "Information Custodian:" },
{ fieldName: "PROPERTY_LOC_DESC", visible: false, label: "Property Location Description:" }
showAttachments: true
featureLayer = new esri.layers.FeatureLayer("http://.../FeatureServer/0", {
mode: esri.layers.FeatureLayer.MODE_SELECTION,
infoTemplate: popupTemplate,
outFields: ["*"],
map.addLayer(featureLayer);
function exeViewRelated(parcelFeature) {
relatedQuery.objectIds = [parcelFeature.attributes.OBJECTID];
featureLayer.queryRelatedFeatures(relatedQuery, function (relatedRecords) {
var fset = relatedRecords[parcelFeature.attributes.OBJECTID];
title = parcelFeature.attributes.PHYISICALADDRESS;
//    content = "<b>Owner Name: </b>" + parcelFeature.attributes.OWNERNAME
//            + "<br /><br /><b>Mailing Address: </b>" + parcelFeature.attributes.MAILADDRESS
//            + "<br /><br /><b>Mailing Location: </b>" + parcelFeature.attributes.MAILLOC
var layerInfos = [{ 'featureLayer': featureLayer,
'showAttachments': true,
'isEditable': true,
'fieldInfos': [
{ 'fieldName': 'PHYISICALADDRESS', 'isEditable': false, 'label': 'Property Address:' },
{ 'fieldName': 'OWNERNAME', 'isEditable': false, 'label': 'Owner Name:' },
{ 'fieldName': 'MAILADDRESS', 'isEditable': false, 'label': 'Mailing Address:' },
{ 'fieldName': 'MAILLOC', 'isEditable': false, 'label': 'Mailing Location:' },
var attInspector = new esri.dijit.AttributeInspector({
layerInfos: layerInfos
dojo.create("div")
dojo.place(attInspector.domNode, popup.domNode);
//add a save button next to the delete button
var saveButton = new dijit.form.Button({ label: "Save", "class": "saveButton" });
dojo.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
dojo.connect(saveButton, "onClick", function () {
updateFeature.getLayer().applyEdits(null, [updateFeature], null);
dojo.connect(attInspector, "onAttributeChange", function (feature, fieldName, newFieldValue) {
//store the updates to apply when the save button is clicked
updateFeature.attributes[fieldName] = newFieldValue;
dojo.connect(attInspector, "onNext", function (feature) {
updateFeature = feature;
console.log("Next " + updateFeature.attributes.objectid);
dojo.connect(attInspector, "onDelete", function (feature) {
feature.getLayer().applyEdits(null, null, [feature]);
map.infoWindow.hide();
dojo.connect(map.infoWindow, "onHide", function () {
featureLayer.clearSelection();
map.infoWindow.setTitle(title);
map.infoWindow.setContent(attInspector.domNode);
map.infoWindow.resize(500, 500);
JohnGillham
Plan B, did you ever figure out how to get this accomplished?  I'm trying to do something very similar (just need to pipe relatedrecords results into attributeInspector and be able to edit).  If you could post/send me any code you have that shows how to do something like this I'd sure appreciate it....  Thanks!
KyleBelott
My caveat here is that I went through a great many permutations trying to figure it out. Ultimately, Esri support told me it couldn't be done using FeatureLayer::queryRelatedFeatures and gave it an enhancement/bug ID of NIM081851, but looking for it now I can't find it. Anyways, I ended up using a query to first select a feature with a mouse click. Second, select the features (records) from the related table using the ID of the clicked feature. I made the AttributeInspector element show up in a content pane instead of the popup too.
I hope this helps.
B
layerInfos = [{ 'featureLayer': activityRecord,
  'isEditable': true,
  'fieldInfos': [
    { 'fieldName': 'FIELD', 'isEditable': true, 'label': 'Record:' }
  { layerInfos: layerInfos },
    "inspectorDiv"
recordTemplate = new esri.dijit.PopupTemplate({
  title: "{PROPERTY_ID}",
  fieldInfos: [
    { fieldName: "RECORD FIELD", visible: true, label: "Record:" }
  ],showAttachments: true
activityRecord = new esri.layers.FeatureLayer("REST ENDPOINT OF RELATED TABLE", {
  infoTemplate: recordTemplate,
  outFields: ["*"],
query2 = new esri.tasks.Query();
query2.where = "DESTINATION FIELD OF RELATIONSHIP = '" + PRIMARY KEY OF SELECTED FEATURE + "'";
query2.outFields = ["*"];
activityRecord.selectFeatures(query2, esri.layers.FeatureLayer.SELECTION_NEW);
