does anyone have an example they could share that uses Dojo's DOH test framework to test dijits which employ the ArcGIS API?
I'm a little confused about how to go about this when the base classes are hosted via CDN. Is the downloadable API or SDK required? Are the Dojo examples I see expect to find a local source folder for all of Dojo.
Is it possible to get an update on the blog post to work with the new 3.2 api and amd loading? It doesn't look as easy to get up and running with dojo 1.7.
