onMapClick event and query feature
2775
5
04-19-2012 11:15 AM
AimeiChen
I am working on migrate a customized widget from flex API 1.3 to 2.4, this feature label widget will allow users to pick a feature layer first then select the field(s) to be labeled, when click on the selected feature on the map, a callout lable will be displayed on the screen. I have trouble with the mapmouse event --it returns "source not found". Help please if you can! thanks
Amy
AimeiChen
Amy
Sorry, I forgot to attach the source code.
RobertScheitlin__GISP
Aimei,
   It will help you greatly to post Flex Viewer/Widget question to the Flex Viewer forum and not here on the Flex API forum.
There is a lot about this widget that is not compatible with the new API. I believe that I have it updated to achieve what it was originally intended to do in 1.3.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote) as shown below:
AimeiChen
Aimei,
Hi, Robert
Thanks for your help. It works now but how can I change the label background color and set up label placement property?
Amy
Amy,
   How did you do that in the 1.3 version of the widget?
AimeiChen
Amy,
Hi, Robert
I attached the source code of the 1.3 version. Please take a look when you get any chance. Please change map service in the xml file for testing.
Amy
