aesalazar
Convert output of an ASP.NET SOAP Web Service to a Layer or Graphics
Discussion created by aesalazar on Apr 20, 2012
Latest reply on May 17, 2012 by wangzhifang-esrichina-com-cn-esridist
Hi everyone.
I am building my first SL app for ArcGIS Server (version 10).  Without going into too much detail, the SL app will sit in a Web App that is using alot of ajax and java to query from a SQL Server database.  So I would like to have the SL app, running a esri:Map object, create a layer of points based on the query result set of the Web App.
The web app is using the MS Ajax's AutoCompleteExtender which relies on a internal Web Service (ASMX File) to return the location id, X, and Y coordinates.  Since it is an ASMX file it will be SOAP and I was hoping to use this same service to map the data in SL.
I exposed the Web Service to the SL App under Service References and can now create a call to retrieve the data which is returned as an array of strings.
My question is, how can I map that array to the SL App?  I essentially need to create a Event XY layer but have not really been able to find any information on how to do that.  Is that even possible with SL or am I better off creating a bunch of graphics?
Ernie
Outcomes
