Cannot Connect to ArcGIS Online via ArcCatalog as GIS Server
4231
04-23-2012 09:20 PM
DarrochKaye
I'm trying to add tasks.arcgisonline.com/arcgis/services as a GIS Server in ArcCatalog however I keep getting the following error message:
We were unable to connect to tasks.arcgisonline.com/arcgis/services. Error: The parameter is incorrect.
I have also tried tasks.arcgisonline.com/arcgis/rest/services to no avail.
Before anyone asks, I am connected to the internet, but as long as there isn't some silly feature I have to turn on in ArcCatalog, I can't see what the problem is. Any help would be greatly appreciated!
DK
DarrochKaye
This problem has been solved. My company's internet settings weren't compatible with Esri's; my work use a Proxy Auto Config (PAC) file which I think was causing issues. Anyway, my IT Dept. worked at it and it is now working.
Cheers,
DK
MikeMinami
Esri Notable Contributor
I don't know why you can't connect. What version of ArcGIS Desktop are you running? You might check the ArcGIS Desktop forums.
Mike
DavidCleland
I am also having this problem.  I just became aware of the issue yesterday.  I cannot connect to the ArcGIS Online services, our internal services or any published ArcGIS Server.  Everytime I attempt to setup a new ArcGIS server connection I am prompted with Error: The parameter is incorrect.
I have confirmed with my co-workers that their systems still work.  Prior to noticing the issue I was ArcGIS 10.0 SP 3, I have tried updating to SP 5 and a repair of my ArcGIS install; to no avail.  We do not use a proxy for access.  Any suggestions would be greatly appreciated!
Update:  Some malware changed my proxy settings. Once that was undone, problem solved.
DarrochKaye
Cheers,
DK
GrahamW
Occasional Contributor II
I had a very similar issue..(incuding hours searching online..) where only my pc was reporting the issue in ArcMap/Catalog
The service worked fine on firefox, arcgis for autocad and Autocad using WMS
it turned out that Internet Explorer (which I rarely use was set to "work offline")
so a quick unchecking of File --> Work Offline fixed the issue
