The Raster to Polygon conversion tool is supposed to work according to: http://webhelp.esri.com/arcgisdesktop/9.2/tutorials/Spatial_23.htm
In my installation of Arc GIS 10, it only works if the raster is thematic but it works for all raster types, multilayer, continuous values, noninteger values etc on my colleagues ArcGIS 9.3.1. installation. We have wasted 2 days trying to solve this problem. All it spits out are error codes which are deadenders.
Has anyone else come across this problem?
Any ideas for a solution?
Is it a systemic problem in ArcGIS 10 or only in my particular installation?
Would appreciate hearing from anyone else who has experienced this problem and/or found a solution.
Thank you for any advice.
Solved! Go to Solution.
In Spatial analyst click on Raster Calculator ->click Int(your raster)->click Evaluate->use your raster calculator result to convert to polygon with Raster to Polygon tool.
Int(("myraster" * 100.00) + 0.5)
