JS API: Map Rotation in 10.1?
2465
04-25-2012 12:14 PM
davidrenz
New Contributor III
Does anyone know if there will be any map rotation capabilities in the JS API in 10.1?
We have a use case which calls for a vehicle to be be moving towards the top of the screen, regardless of actual direction.
Currently, we can use CSS to rotate div map element, but leads to wierdness with panning.
We don't want to use Silverlight or Flex to do this, as JS API is more of a long term solution.
Any thoughts?
thanks
david
ChrisBerryman1
Has anyone figured this out yet? We are trying to create a mobile application for routing, and want the map to rotate based on the direction your traveling so it does not always appear that your traveling towards the bottom of the map.
