Operational Layer Rotation
Discussion created by BV_gisguy on Apr 26, 2012
Latest reply on Apr 27, 2012 by BV_gisguy
I have a Base map that displays in my Flex Viewer at the same rotation set up in the .mxd
My issue is the Operational Layer doesn't rotate and displays in the viewer at an odd angle.
The .mxd I used to create the feature map service is rotated at the same angle, but that doesn't carry through to the viewer.
So... How do you rotate an Operational Layer? :confused:
