jsn
Web ADF 10 and Windows 7: Assembly binding logging is turned OFF
Discussion created by jsn on Apr 27, 2012
Latest reply on Apr 30, 2012 by jsn
Hi all
I am getting the following error message:
<add assembly="ESRI.ArcGIS.ADF.Web.UI.WebControls, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8FC3CC631E44AD86"/>
Line 49:                                <!--Begin Remove for 64-bit native deployment-->
Line 50:                                <add assembly="ESRI.ArcGIS.ADF.Web.DataSources.ArcGISServer.Local, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8FC3CC631E44AD86"/>
Line 51:                                <add assembly="ESRI.ArcGIS.ADF.ArcGISServer.Editor, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8FC3CC631E44AD86"/>
Line 52:                                <add assembly="ESRI.ArcGIS.Geometry, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8FC3CC631E44AD86"/>
Source File: C:\inetpub\wwwroot\Web Mapping Application2\web.config    Line: 50
Assembly Load Trace: The following information can be helpful to determine why the assembly 'ESRI.ArcGIS.ADF.Web.DataSources.ArcGISServer.Local, Version=10.0.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Outcomes
