how to modify VBA as python
840
04-27-2012 12:39 PM
ElaineKuo
I created a VBA to generate a new field (A_new)(season) of polygon and then copy an existing field (A_old) to it.
(For ArcInfo 9.3)
However, there are 500 shapefiles waiting for this task.
The file names are different but share the beginning of C. (For instance, C9568, C4803, and C3208)
Please kindly advise if there is any VBA code to copy the existing fields (C9568, C4803, and C3208)
to the new field with the same name (season) without doing it for 500 times.
Thanks a lot.
Code
Public Sub CreateField()
On Error GoTo eh:
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pMap As IMap
Set pMap = pMxDoc.FocusMap
Dim pLayer As ILayer
Set pLayer = pMap.Layer(0)
Dim pFeatureLayer As IFeatureLayer
Dim pFeatureClass As IFeatureClass
If TypeOf pLayer Is IFeatureLayer Then
Set pFeatureLayer = pLayer
Else
Exit Sub
End If
Set pFeatureClass = pFeatureLayer.FeatureClass
Dim pField As IField
Dim pFieldedit As IFieldEdit
Set pField = New Field
Set pFieldedit = pField
With pFieldedit
.Name = "Season"
.AliasName = "Season"
.Type = esriFieldTypeString
.Length = 6
End With
pFeatureClass.AddField pField
Call UpdateFeatures
eh:
End Sub
Public Sub UpdateFeatures()
Dim pDoc As IMxDocument
Dim pMap As IMap
Set pDoc = ThisDocument
Set pMap = pDoc.Maps.Item(0)
Set pFeatureLayer = pMap.Layer(0)
Dim pFeatureCursor As IFeatureCursor
Dim pFeature As IFeature
Set pFeatureCursor = pFeatureClass.Update(Nothing, False)
'++++++ Loop through each feature and update
Set pFeature = pFeatureCursor.NextFeature
Do While Not pFeature Is Nothing
pFeature.Value(pFeature.Fields.FindField("Season")) = pFeature.Value(pFeature.Fields.FindField("C9469"))
pFeature.Store
Loop
End Sub
DarrenWiens2
MVP Honored Contributor
In Python:
- List feature classes
- Loop through each feature class in the list
- Add a field
- Calculate the field
DarrenWiens2
In Python:
- Add a field
ElaineKuo
Thanks a lot.
It saves a lot of time
TonyAlmeida
Occasional Contributor II
Helenak,
Could you post your code please.
I would like to see how you accomplished converting your vba code to python.
I am working on the same thing.
Thanks.
