Spatial Indexes and Load Only IO Mode
2812
04-27-2012 02:53 PM
NathanHeick
Occasional Contributor II
Good Afternoon,
Does anyone know if there is a difference between using the sdelayer -o load_only_io command versus the arcpy.management.RemoveSpatialIndex() function.  I would like to know if there is anything else going on in the background with load_only_io mode.  We are running several Spatial ETL tools and I want to improve performance during the loading of the data, but don't want the spatial indexes to get rebuilt at the end of any of the Spatial ETL tools.  I am confident the sdelayer command would work, but if the arcpy function is identical, it is much simpler to write a script tool that only uses the arcpy module versus the subprocess module.  I am not sure what can trigger the spatial indexes to be rebuilt.  I want to control when that happens.
Nathan
JonDeRose
Nathan,
'sdelayer -o load_only_io' does much the same thing as the arcpy.management.RemoveSpatialIndex().  Either would improve the performance when loading objects as you would not have the index to navigate.  Load_only_io goes a bit further than the arcpy function however and places a flag on the feature class metadata that will only enable store and replace I/O operations.  In other words, while dropping the spatial index alone will not prevent editing within ArcGIS, setting a feature class to load_only_io will.  Hope that helps.
- Jon
NathanHeick
Thanks Jon,
I was looking for that extra piece of information.  I suspected there was some difference.
Nathan
