Watershed Delineation
722
05-01-2012 12:52 PM
AbbyHils
So I have been working on creating a script that will create watershed for one lake in Ohio. I thought the process was very simplistic in order where you did fill in the sinks of the DEM, do a flow direction, flow accumulation grid, followed by the pour points. All of these are needed steps to create a watershed. I try to run it in PythonWin but nothing seems to run. I am not sure if I did not turn on the spatial analyst correctly or if there was a simpler process of steps to follow.
Any help would be useful!
Thanks for your understanding.
BruceNielsen
Occasional Contributor III
It will help if you include your code. Use the CODE tags (the # button) in order to preserve the indentation.
