Is it possible to start a model directly from an ArcMap-Toolbar?
1758
13
05-02-2012 09:43 PM
MOHAMMEDHABBOUB
New Contributor III
Is it possible to start a model (generated from model builder) directly from an ArcMap-Toolbar? I don't want to start the toolbox just for one frequently used tool.
I have 9.3 edition
thanks 🙂
MOHAMMEDHABBOUB
New Contributor III
Hello everybody,
I found a solution for this problem.. in fact it's another code (see image) and it works
reference: http://gis.stackexchange.com/questions/4952/run-model-arcmap-9-3-1
MOHAMMEDHABBOUB
New Contributor III
Anyone can help?
DanLee
by Esri Regular Contributor
The capability of adding your own toolbar and tools (models, scripts, or system tools) is in ArcGIS 10, but not in 9.3. What you can do is to create your own toolbox and add any of the above tools to it. This video shows how:
http://webhelp.esri.com/arcgisdesktop/9.2/tutorials/Spatial_10.htm
Hope that helps.
MOHAMMEDHABBOUB
New Contributor III
I have wrote this code, but an error appears (see image):
Option Explicit
Private Sub UIButtonControl1_Click()
Public Sub Test()
  Dim pGP As Object
  Set pGP = CreateObject("esriGeoprocessing.GPDispatch.1")
On Error GoTo EH
pGP.AddToolbox ("D:\DRASTIC_MODEL.tbx")
  pGP.MyModel
  Exit Sub
EH:
  MsgBox pGP.GetMessages(), vbOKOnly, "Test"
End Sub
End Sub
reference: http://support.esri.com/en/knowledgebase/techarticles/detail/31110
Anyone can help?
NobbirAhmed
You need to have two Sub or all the code in the Click event. Try this:
First, the Click event method:
    ' Call the Test method
    Test()
End Sub
The second method (Test) is the worker method:
Public Sub Test()
    ' Put all code here
    Dim pGP as Object
    EH:
    MsgBox pGP.GetMessages(), ......
End Sub
Let us know how it goes.
MOHAMMEDHABBOUB
New Contributor III
Well, I'm not sure that I did it right..
In the first method, I did not get it (how could I call test() method?)... see image "FirstMethod"
In second method, EH error appeared ... see image"Secondmethod"
I know that I'm  beginner in VB codes... but I have to learn
Thanks in advance
NobbirAhmed
Your whole code should like this:
Option Explicit
    Test()
End Sub
Public Sub Test()
    Dim pGP as Object
    On Error GoTo EH
    pGP.MyModel
    MsgBox pGP.GetMessages(), vbOkOnly, "Success"
    Exit Sub
EH:
    MsgBox pGP.GetMessages(), vbOkOnly, "Error"
End Sub
Let us know what message do you get?
MOHAMMEDHABBOUB
New Contributor III
error in "Test()" illustrated in image
NobbirAhmed
I don't have a VBA compiler right now. If you google with 'how to call a VB sub' you'll get plenty of examples. I guess the call to Test sub should be:
    Test
End Sub
Without the braces '(' and ')'.
MOHAMMEDHABBOUB
New Contributor III
yes that's right, now both solutions (method 1 and 2) give the same result
