Application crash when zooming to GPS location
4770
5
05-03-2012 01:17 AM
RudolfKopriva
When I start GPS with default auto panning and zoomin quickly several times to the GPS location, the application tries to alloc about 50MB and it crashes on iPad 1. The allocated memory request comes from: AGSGPSAccuracyCircleLayer drawInContext:. I believe it tries to draw GPS accuracy circle without scalling it (so the circle is very large). I have tried to hide the gps on zoomin or even stop gps, but it still renders the circle and crashes. It doesn't happen if I don't start gps at all. How can I avoid the memory allocation?
RudolfKopriva
Found workaround: It was probably caused by my custom implementation of TiledLayer, because it works fine for AGSTiledMapServiceLayer. The workaround was to add AGSTiledMapServiceLayer before the custom TiledLayer. It's strange, because both layers have the same tileinfo and SRS.
NimeshJarecha
It'll be interesting to know why it's crashing with your custom tiled layer. If possible, please share the sample application which demonstrates the issue.
Regards,
Nimesh
RudolfKopriva
Regards,
Nimesh
Thank you Nimesh, you can download the sample from this link: http://dl.dropbox.com/u/37816650/ArcGIS/CustomTiledLayerCrashing.zip
It crashes on my new iPad. You can see the peak and malloc while profiling the simulator. See comments in the code.
NimeshJarecha
The first look at your custom tiled layer says that it's incomplete. You're not setting the _units. Just set "_units = AGSUnitsMeters;" in the init method and it should stop crashing.
Regards,
Nimesh
RudolfKopriva
Regards,
Nimesh
It works, thank you. Excellent support.
