chirag601
Issues on setting up ArcGIS Web Services security
Discussion created by chirag601 on May 3, 2012
I have been strggling with setting up security on ArcGIS Web Services.
I am using ArcGIS 10 server. Through ArcGIS Sever manager I have created users and roles in SQL Server. For secure services I have created sub folder under root folder of the service called "SecureServices" assigned appropriate roles to that "SecureServices" folder and assigned "Everone" role to "root" folder. After setting up everything I have enabled security from Settings. I am following given below walkthrough
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/Walk_through_Implementing_security_with_users_and_roles_in_SQL_Server/0093000000pr000000/
Once I enable the security and try to access that "SecureServices" folder from ArcCatalog using internet connection, after the successful connection that folder is not visible. I can create Token using "Get Token" link on rest page but when I try to integrate that token to map service it's throwing "Unauthorized Access" error. Not sure what's going on.
Any comments are greatly appreciated.
Thank you,
Outcomes
