AnsweredAssumed Answered
FeatureLayer bug when removing from map and adding back
Question asked by chrismorinx on May 4, 2012
Latest reply on May 8, 2012 by chrismorinx
I have an application that removes a FeatureLayer from the map using map.removeLayer. Later on I add it back to the map. It shows up on the map, but if I call the featureLayer.selectFeatures on the layer it fails (never calls the callbacks).
Stepping through the API I can see that the private variable _mode on the featureLayer is set to null when the layer is removed from the map, but never re-assigned when put back in the map. The selectFeatures code expects the _mode variable to be set. I believe this is a bug in the API.
Cheers,
Christian.
Outcomes
