Deleting graphics from a feature layer programmatically
1235
05-04-2012 08:11 AM
MarvinOconitrillo
New Contributor III
I was trying to delete some graphics from my feature layer depending of one attribute, however when I loop on the graphics collection it says that have zero elements.
for (int i = flCalificacion.Graphics.Count - 1; i >= 0; i--)
   grafico = flCalificacion.Graphics; //tomar el elemento gràfico
   if (derroterosBorrar.Contains(grafico.Attributes["ASIENTO"].ToString())) //si tiene el mismo nùmero de presentaciòn
           flCalificacion.Graphics.Remove(grafico); //eliminarlo
   }//fin if
}//fin for
flCalificacion.SaveEdits();
I'm using the feature layer in Ondemand mode, should I use another one?, or there is another way to get the graphics collection from my feature layer to loop and delete it?.
Any help will be appreciated
DeminHu
lookt the following  and see if you could find something helpful.
try
                FeatureSet fSet = args.FeatureSet;
                if (fSet.Features.Count > 0)
                    foreach (Graphic g in fSet.Features)
                        string objId = g.Attributes["OBJECTID"].ToString();
                        for (int i = 0; i < _plumeFLayer.Graphics.Count; i++)
                            Graphic selectedGraphic = _plumeFLayer.Graphics;
                            if (selectedGraphic.Attributes["OBJECTID"].ToString() == objId)
                                _plumeFLayer.Graphics.Remove(selectedGraphic);
                                // _plumeFLayer.Update();
                        } // end for
                    } // end foreach
                 // depends how you set AutoSave mode, if it it  true, you don't need the following
                    if (_plumeFLayer.HasEdits)
                        _plumeFLayer.SaveEdits();
               } //e nd try
            catch (Exception error)
JenniferNery
It is okay to use OnDemand mode.
FeatureLayer.Graphics may be empty because UpdateCompleted event is not yet raised. You can subscribe to this and have the following event handler. Note that in OnDemand mode, this will be raised every time your map extent changes so if you want to perform the delete once, you need to unhook from this event.
  private void FeatureLayer_UpdateCompleted(object sender, EventArgs e)
   var l = sender as FeatureLayer;
   if (l.Graphics != null)
    var graphics = l.Graphics.Where(g => (string)g.Attributes["STAGE"] == "tropical depression").ToList();
    foreach (var g in graphics)
     l.Graphics.Remove(g);
dotMorten_esri
Esri Notable Contributor
Also note that if the layer isn't added to a map (or the map hasn't loaded), the featurelayer will never query for any features (it queries features based on the map's current extent).
İsmailZAMBAKCI
You can use update method after initialize FeatureLayer to load graphics .
#Sample codes#
FeatureLayer fl = new FeatureLayer();
fl.DisableClientCaching = true;
fl.Mode =  FeatureLayer.QueryMode.OnDemand;
fl.Url = "http://ServerName/ArcGIS/rest/services/ServiceName/FeatureServer/LayerID";
fl.OutFields = new OutFields(){"*"};
fl.Initialize();
fl.EndSaveEdits += new EventHandler<EndEditEventArgs>((c, d) =>
    MessageBox.Show("saved");
fl.Initialized += new EventHandler<EventArgs>((a, b) =>
    fl.Update();
    fl.UpdateCompleted += new EventHandler((c, d) =>
        fl.Graphics.Remove(fl.Graphics[0]);
        fl.SaveEdits();
